mudcat555
- Retired Electrician IBEW Local 38
I am going to be splicing a copper conductor to an aluminum conductor. Is there a split bolt made of a specific material that I need to use?
What size conductors? There are some set screw barrel splices that I like better than split bolts.
These are good if you have the tool.View attachment 13544
but if you had the tool, you would know that already.
Better yet, these:
Made by Ilsco.
or polaris.... these get my vote over a straight split bolt.
:thumbsup:
While the compression tools are a bit expensive, the connectors/splicers/adaptors are less than the screw type mechanical ones. I think the long term investment of compression tools is worth it.
