I fished it up to the panel, ran it out to my disco where i sleaved it in pvc. Its for a mini split ac unit.
I see, I thought you were talking about the feeder to the Panel.
JAP>
I can see the inspectors point if it is a mobile home, Earlier you said manufactured home. Which is it? The nameplate should contain a substantial clue... :happyyes:So the head inspector is saying that since these are mobile homes, its important to keep them ready to travel. I dont see that in the code, its not in the WAC, or HUD. I believe if the code meant for all under chassis wireing to be in conduit it would say just that. It wouldn't say if exposed to weather.
Still, the second part of my post has it covered either way. :angel:Double wide manufactured. WA state considers it a mobile home
That's more what I had in mind. An afterthought says using tie downs for anchorage has no bearing on this matter. I back on your side of the fence, FWIW... :angel:By pitted, I mean that the crawlspace is dug out and the home sits down on a block foundation. The floor of the home is ground level and the crawl is a couple feet down like modern stick built. Not like the old mobiles they pulled in place and put up skirting, although I would still contend that since they're skirted they are not subject to weather either.
Depends on details, as always.Well I've decided to give up. Im most likely going to run exposed EMT from now on. I have abother question though, in regards to 352.44. If I run PVC under the trailer am I still required to install an expansion joint, since it would be subject to tempature difference? Thanks for your replies.
Probably... but I don't know of any published data... so you'd have to measure the ambient temperature in the dead of winter and heat of summer to determine.It would be probably 20' between points, if it was run outside it would need an expansion fitting. Im just wondering if there is any difference since its underneath the home. Also, it seems like it would be hard to use the proper pvc straps. I could probably use beam clams and minis but I doubt I could get them every 3 feet. Seems like my only answer is EMT.
