box fill
is there any easier explanation.
For example how many #2 Wires I can splice in 8x8x6 splice box?
The limitation is based on the box being big enough to comply with the 6X and 8X rules. If you could get 40-#2's in the box and still comply with the straight and angle pull rules then you would be code compliant.
still don't get that.
I know to #6. but larger then that.
witch table in code book tells me how much space conductor takes.
i tried to find it but i can't see it.
Again there is no cu in size for larger than #6 conductors and there is not table.
