tadavidson
- Georgia
- Electrical Contractor
Hi all, It's been several years since I've been on this forum. Now I have a perplexing situation. I have a sub panel located 15 feet from the main 200 amp panel. The sub panel is 100A. It is fed with SE cable and has a driven rod with #6 bare to the driven rod. Today I was called out because of unbalance voltage on the system during the use of a pump motor. The pump motor is fed from a sup panel off the First sub. When the pump motor starts the voltage across the Main breaker in sub panel 1 goes to 180 volts to ground on A phase. I know I have integrity on the grounding electrode that is connected to the "neutral" bar. What am I missing?
