JohnDS
- Suffolk, Long Island
- Electrician
Customer does not want to disturb the other existing services. I'm thinking I can either:
A) Install meter to the left of other meters, out top with galvanized, sweep to the right and up, through lower soffit and then up to other weatherheads.
B) Install meter on right side of existing meters. Go up with pvc, 90 degree left and then offset over both existing risers.
C) Same as "B)", except screw pvc to the bottom of top soffit instead of offsetting around existing risers?
What would you guys do and do you see any potential issues with Utility and/or inspector? I cannot sell the customer on combining one of the meters into a 2gang meterpan and he does not care about physical appearance otherwis i would have just did a 3gang meterpan.
Sent from my SAMSUNG-SM-G730A using Tapatalk
