teufelhounden91
- Austin, TX, USA
I have another spine tingling Yum Yum discussion to get into. Are you ready?
In the industry we often hear of shorts versus dead shorts. In the codebook it only ever talks about short circuits and ground faults. I don't believe it ever mentions the term dead short or deadbolt short, or even short for that matter. Only short circuits and ground faults.
My quandary then is on terminology and straightening out with the terminology means. Shouldn't we be using the terminology short circuit or ground fault to describe what is going on in the circuit? Not short and dead short. Correct me if I'm wrong but if a hot touches a neutral somewhere before the load this is a short circuit. Regardless if there is an arc or some other huge resistance/voltage drop and it takes awhile to trip the OCPD (short) or if it is directly touching and the OCPD trips instantly (dead short), it is still just a plain old short circuit. A ground fault on the other hand is when a hot touches ground regardless if there is an arc or it is directly touching.
My boss says a powerline laying on the ground is "a short, not a dead short." I disagree, I believe this is a ground fault. However technically he is not wrong because current is leaving source traveling through ground and getting back to the source neutral. There's no load in the circuit unless you view a swing set and chain link fence on fire as resistors. So if we take the swing set and fence out of it, this becomes a dead short?
https://www.youtube.com/watch?v=28Xq3JulV1o
And while we're on it, what about when a hot touches another hot? Is that still considered a short circuit?
