I have machinery that will have a primary system, and an identical system as a secondary system. Both systems will be powered by 460Y/277 VAC. The primary electrical enclosure will be located outside in the Northern US.
The enclosures will contain Circuit breakers, distribution blocks, contactors, relays and Soft Starters.
The soft starters are the only component that contain electronics.
My primary concerns, especially for the soft starters are the heat/condensation in the summer and cold temperatures in the winter. For example, it is -10 C outside, the primary system fails and the secondary system powers up. The secondary system's soft starters may fail if started below freezing.
It is hard to make the enclosure suitable for both winter and summer. Heaters don't like ventilation, for example. So I think the best solution is to use an air conditioning system coupled with a heater.
The AC system is expensive, so i would like to, if possible, place both sytems inside the same enclosure. Is this even possible? One enclosure, but with 2 disconnects for two seperate power drops? Would all the wiring inside the enclosure have to be orange? Is there any way to access a single cabinet with two disconnects? Can I use a dual cabinet, with seperate doors, but somehow share a refrigeration system?
