howardrichman
I'll be wiring a 30 amp 220V hot tub; outside set on a slab against the house. I'll be installing a 10-3 romex from a sub panel to a weatherproof disconnect located at least 5ft from the tub units water edge. I'm considering the 50 amp GFI and enclosure Home Depot carries as a set, instead of separately buying a DP 30 GFI and separate enclosure. is it permissible to fuse the tubs line at the sub panel @ 30 amp and install a 50 amp GFI @ the tub disconnect?
HR...
HR...
