Underground cables are rated for damp and wet locations, but it is not stated if it can handle being totally under water for long periods.
Also UL description of wet location is just splashes, flows etc.
Can water treeing on xlpe be accelerated?
my experience has been that underground cables exist in continuous immersion
within conduits between vaults, without significant problems.
this was last winter, and while the vault was pumped out, and wires terminated,
this particular vault has about that much standing water in it right now, and
has had for most of this year... all of the 6,000' of conduit in this project is full
of water, and remains so. i have no doubt it'll stay like that for an indefinite period
of time. wire is southwire simpull.
i'm pretty sure that wire will be here energized long after i'm gone.
when i pulled this project, i meggered phase to phase and phase to ground on
each pull before i cut it free from the spools, so i'd know if i had any problems.
the readings went into the asbuilts. i'll probably down everything next spring or
summer, and see how the stuff is holding up.
