ggunn
- Austin, TX, USA
- Consulting Electrical Engineer - Photovoltaic Systems
I still don't see why you want to do this. If you run the + home runs under the array back to where the - home runs tie in, the wire length is the same and you avoid this issue altogether.I attached a picture to show what I am questioning. As you can see thirteen modules are across with negative on one side and positive on the other.
