"hot top"?
jaggedben
Northern California
What does the phrase "hot top" mean to you?
Full context:
AC Disco [for a solar system] required only where meter and main panel access it inhibited, where a hot-top is the point-of-interconnection, or where NEC/CEC require one.
my wife has one, but i suspect thats not an answer you are looking for ;)
Bump.
Anyone else have input on this?
I think ggunn's guess is a good one but it also goes without saying that a supply-side connection needs a disconnect. I'm wondering if 'hot top' means anything technically specific to anyone, particularly in a non solar context.
Bump.
When you first posted the question I googled the phrase and came across the same thing you posted. I thought then (and I still think) it's a typo. "Hot TAP"?
Maybe see if you can contact the author?
I've seen the same phrasing in several places so I don't think it's a typo. It appears in some AHJ's requirements for PV systems, and then re-appears in a couple sites I use that collate info about PV permitting.
I will probably just try to ask one of these AHJs if/when I get a chance. I have a feeling they are also copying from each other and anyone I talk to may or may not know the original author's meaning. :slaphead:
