We're required to use CADWELD for transformer grounding on our next project. I am specing out the components for the job. We will use 2/0 bare copper cable, and weld to 5/8 rods.
I want to use the reusable system (as opposed to one-shot) and I am was hoping an experienced installer could assist with the components and tools required.
The parts I have identified so far include:
GRC162G Cable to ground rod
GTC162G Cable thru ground rod
then we will use 2/0 compression lug to attach to transformer.
I have an issue identifying all the components needed to make these connections. Do they come with everything, or do I need to order the weld material separately
-> 200 or 200PLUSF20, Sold Separately
Thanks if you have time to assist.
Chris
Chris
