- Licensed Electrician
Go all out and then some if it is a feeder, but if it is just a MWBC you settle for unprotected UF? Is that what you are saying?Hopefully its not nm going to the bldg.
Id probably run rmc from the house if theres a panel in the garage. Use the rmc as the egc plus a suplemental gec for the panel.
If its a single or mwbc Id. run uf
Sent from my LGLS770 using Tapatalk
Other than some extra breakers and driving a ground rod at the garage for a feeder what is the difference between the one or the other?
