Gary Alzaga
- montebello, Ca
Seems like this should be an easy code section to find but I'm having trouble finding it.
Heres the scenario. A 4 gang meter section at a multifamily dwelling property. The meter section will feed 3 units and the property lighting and gate motor. 3 + 1 = 4. Each service disconnect will be 100 amps. FYI the units are 900 sq ft with only the basic alliances. The load calcs are way below 400.
My my question is. What code article might tell me how to size the service entrance conductors. Specifically that they can be sized below 400 amps because the odds of the tenants ever pulling 400 amps from the service is are very unlikely or that it must be sized based on the sum of all the disconnects in that service.
Any advice helps. Thanks.
