Kaybeeoh84
- Lake Charles, La, United States
I am wondering if running a separate wire from the ground bar on the interior panel to the meter enclosure is good practice or a potential hazard. I am aware that you are effectively paralleling the grounded conductor in doing so and that most meter enclosures are factory bonded from the can to the grounded conductor. I am also wondering if there would be any potentially hazardous current flowing through the #4 wire (I'm assuming there is, since electricity takes all paths; not just the path of least resistance) or if the resistances of the two wires are different enough that the current flow would be miniscule. My second question is: if there is a loss of the grounded conductor on the poco's side, what measures could be taken to reduce the potential of the meter enclosure and/or the GEC from becoming the path back to source? I am a city electrical inspector and would like things to be as safe as possible, with respect to practicality. Thank you, in advance, for any comments regarding these matters.
