I am currently stuck with a PLC that only has RS232 and RS485. I can easily add a USB to 232/485 converter. However, if I cannot use the USB to daisy chain several PLC's.
RS485 simultaneously transmits to all devices on the network. There is no retransmitting the signal. The same signal gets applied to all devices.
Would I be able to take a single USB to to RS485 converter for the main PLC, and then daisy chain the converted RS485 between the PLC's by using standard USB connections? I would use USB cables and connectors but have them connected to RS485. I currently use RJ11 jacks, but wouldn't the USB connectors work the same?
The USB connectors only function would be RS485.
Any other suggestions on how to daisy chain USB's?
