Bucket truck CDL
You should not need one for that truck
Class A CDL drivers. Drive vehicles weighing 26,001 pounds or greater, or any combination of vehicles weighing 26,001 pounds or greater when towing a trailer weighing more than 10,000 pounds. Transports quantities of hazardous materials that require warning placards under Department of Public Safety regulations.
CDL requirements can vary by state. but I would say No. Basically, "Any single vehicle with a GVWR of 26,001 or more pounds, or any such vehicle towing another not in excess of 10,000 pounds."
Anybody know the weight a bucket truck has to be before you need a CDL?
A truck exactly like this one is what I'm wondering about.
https://www.flickr.com/photos/navymailman/6650591463
You won't need a CDL but the truck needs a DOT number for 10000lb gvw and over. This doesn't account for state regulations.
....aaaaand the driver needs a DOT Medical Exam and Commercial Motor Vehicle Certification for any vehicles over 10000lb-
See more at: https://www.fmcsa.dot.gov/medical/d...or-vehicle-certification#sthash.3SgixmUN.dpuf
This is why they make 9900lb gvw box trucks, to get around it
I believe that only applies if you operate the vehicle across state lines. If all of your work is within one state you don't need the medical.
Oh yeah, I forgot to mention it but, I tow a scissor lift around too.
I am very sure it does in Illinois and I believe that comes from the federal CDL rules.
I was looking into that and I found the wording is a bit tricky and not quite uniform between different sources. My final conclusion is that if the trailer is over 10000, the combination cant be over 26000 or else a CDL is required. If the trailer is 10000 or under, the combination can be over 26000, as long as the truck itself isnt.
http://www.cdltrainingconsultants.com/Who_Needs_a_CDL_.html
Whew....Ive been pulling my 14,000 GVWR dump trailer around quite a bit lately and I dont have a cdl.
Hee
Here is what Illinois says. You are closer to being right than I was.
[h=2]
Vehicles Requiring a CDL
[/h]
  • Any combination of vehicles with a Gross Combination Weight Rating (GCWR) of 26,001 pounds or more, providing the Gross Vehicle Weight Rating (GVWR) of the vehicle being towed is in excess of 10,000 pounds.
  • Any single vehicle with a GVWR of 26,001 pounds or more, or any such vehicle towing another not in excess of 10,000 pounds.
  • Any vehicle, regardless of size, designed to transport 16 or more persons, including the driver.
  • Any vehicle, regardless of size, required by federal regulations to be placarded while transporting hazardous materials.
CDL and Non-CDL Classifications
  • Class A — Combination of vehicles with a GCWR* of 26,001 or more pounds, providing the GVWR of the vehicle being towed is in excess of 10,000 pounds.
  • Class B — Single vehicle with a GVWR* of 26,001 or more pounds, or any such vehicle towing another not in excess of 10,000 pounds.
  • Class C — Single vehicle with a GVWR* of at least 16,001 pounds but less than 26,001 pounds.
  • Class D — Single vehicle with a GVWR* of less than 16,001 pounds.
  • *GCWR — Gross Combination Weight Rating
  • *GVWR — Gross Vehicle Weight Rating
[h=2][/h]
I am required to have the medical and I work in in Washington,but the rules can vary by state. The most recent change is you need proof of citizenship to renew or apply for CDL
