I've said in other topics and posts that classified locations isn't rocket science but it isn't quite trivial either. In this case, the "book" you referred to is the NEC, Articles 500 and 502 supplemented with NFPA 499, Recommended Practice for the Classification of Combustible Dusts and of Hazardous (Classified) Locations for Electrical Installations in Chemical Process Areas.... Is there a book someone could recommend on the subject?
Outdoors generally not classified, someone will disagree but will probably have something specific that maybe does create a hazardous location.
NEMA 3R still not a good idea in higher dust concentration areas as it finds a way into 3R enclosures, you want gasketed enclosures.
Indoors, housekeeping practices can make some difference between division 1 and division 2, but in general most areas are division 1 unless you are qualified (and willing to take on liablilty) to call them division 2.
Another thing that is outside the scope of hazard locations but is a common problem I see a lot is arranging raceways to drain condensation - it will happen.
Normally the gasketed enclosures we work with are galvanized nema 4x and nema 12 with the piano hinge and in an underground tunnel they seem to seize up. Is there an enclosure with the gasket and the lift off lid? Also where is the condensate supposed to drop out if you are using sealed boxes? With a 3r it can drip out.
