Stevenfyeager
- United States, Indiana
- electrical contractor
Hi, unequal voltage readings usually means a loose contact of the neutral. We've all encountered that many times. But a new subpanel I installed has readings of 122 volts on one lug and 119 v on the other. Is that enough difference I should be concerned? I haven't checked voltage in the main panel yet. Thank you.
