Found this explanation on the Siemens site:
"What is the difference between Branch Feeder and Combination Type AFCI?
Both branch feeder and combination AFCIs provide conventional thermal and
magnetic overcurrent protection as well as high current or “parallel” arcing fault
detection and fire mitigation for installed wiring and connected cords. The
combination AFCI has the added benefit of enhanced detection of persistent low
current or “series” arcing faults which mitigate fire hazards in cords connected to
outlets."
I have a problem with a Combination Type AFCI on a circuit with a lot of electronics. Just wondering if anyone else out there has encountered the same problem? It appears that the tripping occurs when the electronics go into sleep mode or meet the definition of "persistent low current" programmed into the CAFCI
Please no flaming the AFCI.....I don't want this thread to turn into a bitching session. I already know what most of you guys think of the devices.
I going to try to swap out the problem CAFCI with a Branch Feeder type to see if the problem goes away.
outlets."
