- Licensed Electrician
You are right. They don't.I may be missing the obvious, but I still don't see why reverse polarity will trip GFCI.
I can hook old 2/wire romex to GFCI receptacle and nothing to ground screw. If I have reverse polarity will it trip? If not, and I then add ground, will it now trip?
If you hook up line and load backwards they will not work since sometime around 2002.
