xguard
 - Baton Rouge, LA
I've seen rigid galvanized steel conduit be required to be connected to a ground rod where the rigid conduit transitions below ground and then the run changes to PVC. Is there an NEC requriement to do this? Is there any benefit to doing this?
EXAMPLE:
A typical installation would have the RMC bonded to a service disconnect. The RMC would then enter the ground (dirt, maybe concrete then dirt), be connected to a ground rod, then the run changes to PVC. The conduit contains an Equipment grounding concutor and neutral.
Typical Load side installatio - The PVC conduit mentioned above continues underground until it reaches a structure, the conduit run transitions back to RMC while still underground. The RMC is connected to a ground rod. The RMC is also bonded to a small panel or fused disconnect.
I can't see where the RMC connection to a ground rod is required by code or has any particular benifit. Thanks for any feedback.
			EXAMPLE:
