clsarmiento
I have a situation wherein a 50KVA, 240/120volt, single phase, 3-wire step down transformer is fed from a 480volt meter/service disconnect.
The secondary of this transformer feeds an automatic transfer switch (ATS), which in turn feeds a panelboard with 200amp MCB. The step down transformer, ATS and panelboard are all in the same line up and within sight of each other. Distances are the following: From service disconnect to ATS = 8feet; from ATS to panelboard = 5feet. One jurisdiction did not require overcurrent protection on the secondary side of the transformer ahead of the ATS; another jurisdiction is requiring an OCP ahead of the ATS in compliance with NEC 240.21 requirements. What is the correct interpretation of NEC 240.21 (C) on the foregoing situation? Thanks.
