Comcheck and track lighting with LED track heads.
Nowadays in almost every state you pretty much have to use current limiters to pass energy code if you're using a lot of track. As stated earlier, you use the current limiter values when calculating your load. Make sure when you are sizing the current limiters to add 125% unless you're using Juno CL's (they already have it factored in) - not sure if any other brands do or not.
-Drew
