senoirbubbles
- Clearwater, Florida
I recently ran into an older commercial building with multiple units. There is a 800 amp disconnect that feeds a trough with approx 6-200 amp disconnects. My question is regarding one of the 200 amp disconnects. On the load side of the disconnect 3/0 wire feeds into a junction box in the ceiling about 10 feet from the disconnect. There in the junction box they split off via 2/0( it could be 3/0 I need to look again) wire to two separate MLO panels.The panels are about 20 feet away from the junction box. No EGC was run from the Main disconnect, I assume the conduit is being used as the ground. My questions are:
1) Is this up to code? I have never seen two panels run off of one disconnect and do not think the tap rule can apply.Would it be okay if each panel had an OCP?
2) Assuming the panels are wired correctly, Would I be required to add a ground wire or would the conduit suffice as the EGC for the panels.
