five.five-six
- california
All I can say is wow, I was just pointing out that you won't ALWAYS have "full voltage" and a "full shock" on an open nuter.
Depending on the means and frequency of testing your theory, you may not have "full life expectancy" either.All I can say is wow, I was just pointing out that you won't ALWAYS have "full voltage" and a "full shock" on an open nuter.
Could you explaine exactly what you mean by that? Like most of your posts that as clear as mud.Depending on the means and frequency of testing your theory, you may not have "full life expectancy" either.
How do you receive a "full shock"?Could you explaine exactly what you mean by that? Like most of your posts that as clear as mud.
perhaps if you didn't speak in riddles and just say what you mean like grown men do. That would be great.How do you receive a "full shock"?
What is the worst possible outcome of that shock? Hint, since most of my posts are as clear as mud: insert fatal where you think it might fit.
And FWIW, my posts may just be clear as mud so you to think for yourself. It could save your life, or at least extend the quality of life you currently experience.
My dialog is typically reactionary. What you get is what you bring out of me. I've been around long enough to know those who are condescending are on the opposite end of any stick they think they are holding. Is that as clear as mud for you.perhaps if you didn't speak in riddles and just say what you mean like grown men do. That would be great.
I agree... I'm not here to babysit.Perhaps you two should take a break. This dialog is doing nothing but causing grief. Please stop. Thanks
And you are correct, but not for the reason you stated.All I can say is wow, I was just pointing out that you won't ALWAYS have "full voltage" and a "full shock" on an open nuter.
I finaly convinced the building owner to pay me to trouble shoot this problem. It's really strange. I have found 2 sparking conduits, the 2nd more recently repairing a switch with a glowing connection. today I took amperage and voltage to ground readings. It's 10 volts and 9.5 amps from one conduit to the sprinkler system. I used the sprinkler system because there's nothing in the building I trust to be ground. Anyways, this conduit, I traced it out from the place I found the potential. There are only 2 devices after this Jbox, I verified this with a fish tape. There is one circuit feeding these 2 devices (receptacles) and even with that circuit de energized, I still get the 10 volts and 9.5 amps to ground. I think I need to rip the wall open to find out what's energizing that conduit.
Would turning off circuits until that reading goes to zero, then tracing from there work? or finding the breaker with the (extra) 9.5A draw? before walls start falling...
thx for the update; what else failed to prompt the customer to pay you five months after the initial problems?
???...it's a working business and it will have to be MW work. ....
