Yes, it is an application of the Law of Cosines. Your formula is for full boat. For only two loads it reduces to the square root of (a² + b² - (a*b)).The neutral current, assuming that the phase angles are 120°, is equal to the square root of (a² + b² + c² - (a*b) - (b*c) -(a*c)).
I think the trig function is the law of cosines, but not sure.
What if I am using A and C phase?Yes, it is an application of the Law of Cosines. Your formula is for full boat. For only two loads it reduces to the square root of (a² + b² - (a*b)).
Remove all elements of "b", as they will calculate to zero...What if I am using A and C phase?![]()
Now can we do B and C?Remove all elements of "b", as they will calculate to zero...
... the square root of (a² + c² - (a*c)).
C'mon now! It's not that hard to figure out. :blink:Now can we do B and C?![]()
What is mwb?
MWBC-Multi Wire Branch Circuit
I think he is messing with you...even the first time. :lol:C'mon now! It's not that hard to figure out. :blink:
I thought that may be the case, but answered on the off chance he was not. Second time made it much more obvious.I think he is messing with you...even the first time. :lol:
