jasonsim
- Reisterstown MD
Im trying to add an occupancy sensor to turn off lights that keep getting left on as cheap as possible and keep the three way switch.
The lights are all LED. Two are recessed floods at 9 watts each. The other two are fluorescent fixtures that have been retrofitted to 2 18 watt LEDs ballast bypass (36 watt total).
Total watts 90
Total amps 0.75
I will need to add a ceiling mounted motion sensor that will turn the lights off if left on.
I dont want to spend the money on two three way motion sensors and a ceiling mounted sensor.
The only way I can think of making this work is to put the ceiling mounted sensor in series with the three way switches, but this would turn the power off to the sensor every time the switch did get turned off. I dont know how the sensor would react to on/off power.
Any ideas? Is there a sensor designed for this kind of operation? Remember Im trying to keep it cheap, under $100 for sensors.
Total watts 90
Total amps 0.75
