Ryan Currin
- Allston MA
My questions pertains to the grounding requirements of aircraft hangars. We are building 6 new aircraft hangars total distance 375 feet. Each one will have a new slab. There will be a new 7 bank meter service on one side for the entire structure. The local electrical inspector mentioned the need for eccentric grounds to be used. By code, what kind of grounding system do I need to install other than 2 ground rods at the service, cold water ground, and building of steel.
Thanks
Thanks
