mnbiker
- st.paul mn
Just finished a install on a new oven here at work. 192 kw at 480 volt. I took some current reading at first start up. all phase conductors were at specs. I noticed the grounding conductor had about 2.5 amps on it. I check other grounding wire in control cabinet, the grounding wires going to the wattlow controls each had between .2 and .4 amps each, which adds up to 2.5 I have on the main grounding wire going back to switch gear.
is this consider objectionable or acceptable.
thanks
thanks
