jetlag
- Eatonton, Georgia
I think I was using the 2008 nec when I was running the circuit for the smoke alarms . The info I had said the smoke alarms had to fed off of a lighting circuit so you would be sure to know if the circuit went out . Now I have seen where the smoke alarms can't be on an arc fault circuit. So how do I correct that , the lighting circuits are all arc fault in that house now . The house interior is still in rough in stage and I can change the wiring
