MechEdetour
 - NY, USA
 - Design Engineer
This really isn't code related, more of an application question. But I know there are a lot of people here that have experience with controls so I'm gonna give it a whirl.
Is there a component/device on the market that can take a digital output from a device to drive its contacts? I am talking something very simple that doesn't rely on software or programming or anything like that to get it done (such as PLCs). Maybe some sort of relay, but possibly it's called something else?
If I had to simplify things, it'd be something like this:
The device that provides the signal has two states. 0V, or it pulls high. Max sink current for the terminal that provides the signal is 50mA. I want to take this signal and use it to power a coil that would drive contacts rated for 3A at 24V.
There are relays on digikey that have contacts rated for what I need and the coil requires as little as 9mA to switch the contacts (only like $10). Since the digital realm is a bit new to me, can the max 50mA sink current be utilized in a way to drive the coil on a relay? Yes it is either zero or it pulls high, but is there a way to wire a 24V supply across "some coil" to drive some contacts?
The theory behind it tells me it should work. But then my doubt comes from the fact that I'm trying to use a 0V/float signal to power a coil. . .
I started with asking if there is something out there, and I ended with I think there is something will it work.
Thoughts? Will it work? If not, is there another way?
