Once upon a time, before computers, it was a coax or maybe RCA jack.I have not ever given a presentation myself. But I have been to plenty where the presenter brings his own laptop and presumably connects into a outlet on the wall. What is that outlet? USB? HDMI? VGA? More than one? (Why have I never looked?)
I don't know limit on HDMI length, but what is severe? I have seen 50 foot HDMI cables, more then that I usually see adapters that convert to a pair of CAT 5/6 cables then adapt back to HDMI on the other end. I seem to recall seeing similar adapter in catalogs that uses coax cable between but I always seen the CAT 5/6 adapters in the field.Once upon a time, before computers, it was a coax or maybe RCA jack.
Next came VGA. Maybe old Apple style digital video connector.
I do not recall ever seeing USB for that purpose. It went straight to HDMI from there. But the length of HDMI cable is severely limited unless a range extender is incorporated.
They do now, sometimes in addition to a specific connector for external displays, so that you can watch movie from your computer on your large screen TV.The projector information is limited to direct connections assuming you can go straight from the laptop to the projector.
The projectors usually have all the connections.
Do lap tops have HDMI? (i'll go in the other room and look)
We recently ran VGA through composite extension cable with adapter ends as well as a separate long HDMI (around 40 ft). Both connect directly to projector.ceiling installed projector:
What wiring is usually installed from the projector to a wall connection (jack) for a laptop connection?
Is the cable installed right to the projector or to a jack near the projector (next to the receptacle)?
VGA & HDMI will cover most laptops that will come in. It would be nice to have some kind of multi-converter but I haven't really looked. We had issues with a wireless we tried and just stuck with an HDMI cable for that location.I have not ever given a presentation myself. But I have been to plenty where the presenter brings his own laptop and presumably connects into a outlet on the wall. What is that outlet? USB? HDMI? VGA? More than one? (Why have I never looked?)
