Any problem running a 240 v dryer on 208 v?
I hear this scenario all the time and IMO it is done because the dryers must be cheaper at 240V vs 208V
And because dryers built for 208 cannot be used on 240 while 240 can be used on 208 as long as motors are not involved.Probably something to do with economy of scale. More production of dryers built for single/duplex family dwellings that have 120/240V services, than for dwelling units of large apartment complexes that have 120/208V phase-to-phase "sub-services".
If the dryer motor is 120V, would it matter if it were 208 or 240V service? Either way it is 120V ungrounded and a grounded conductor. Are the motors typically L-L vs L-N?
I have seen straight 240V dryers but they are not common
I would think that the unit would say 240/208. To be honest I don't rememberAnd who knows, they may have a motor which is rated for either 208 or 240....
Maybe.It will take a LOT longer...
The motor is at the same speed, there is 25% less heat applied.
If one looks at a psychometric chart, and does the calculations, and accounts for heat loss thru the dryer case, you get about 3X as long to dry.
Gets even worse for old dryers, where the NiCr wire has oxidized and gone up in resistance by 10-20%.
Had some 240 V appliances at the school once, needed to put auto transformers on the line or the workers complained about everything from clothes taking long to dry to water on the electric stove in big pots never even being able to come to a boil. (208/240)^2 = 75%
Guys, have you looked at the tag on most residential dryers?
They are rated for both 208 and 240, they provide KW ratings for each.
