david
- Pennsylvania
Yes.
There is absolutely no need to "protect" the utility feed any more than it is, but downsizing the 200A main to 175 will remove any possible argument about the stretch of 200A SEU between main and next panel down.
And for some AHJs that is a valid concern.
what about the conductor i labeled B would you up size that to a 140 amp value if applying the 120% calculation must be applied up stream.
