Housekeeping/ messy connections
Designer69
please see attached pic. Client is concerned about this messy setup. plug-cord cables from terminal box wound-up and running under cable trak. Pretty tangled up, could be a trip hazard etc.
anyone know of a way to clean this up a bit? Not by installing underground conduits or anything. needs to maintain the quick connect/disconnect configuration. There may not be any other way but I just wanted to check.
Thanks
What exactly is this? Any way to install pendant receptacles/boxes instead?
I can't tell what it is either.
And I thought cable track was usually for things that move a lot - like a motorized work table, a CNC, or a robot arm?
It looks like the equipment is on the ground or floor, and the stuff at the top is mounted on a wall? Is that right?
sorry for late response. These are diesel driven air compressors used as backup to supply service air on low SA pressure. they are pretty critical for operation so it definitely would be a good idea to have a cleaner setup.
I like your ideas of hook/bracket on wall with cable reels. Thank you!
