Would a totally aluminum car trip a traffic light ( induction type ) ?
Is this a hypothetical question or a problem you are having?Would a totally aluminum car trip a traffic light ( induction type ) ?
Along those lines, to better detect metal close to center of the loop without causing too high a sensitivity to what is in adjacent lanes, detector loops that need to reliably detect bicycles are wound as magnetic quadrupoles (figure 8 loop) instead of dipoles (traditional single loop).... so they try to make sure for example that the loop detects a bicycle rim, but not a big shiny silver belt buckle on a pedestrian's jeans.
Back when I rode a motorcycle, I had little patience for stoplights. After coming to a stop on the loop, I would kill the engine. I would immediately start the engine with the electric starter in the belief that a field coming from the starter would trigger the loop.
So they can write tix for running red lights without having to have a cop on site.In newer installs the use of cameras is preferred for both cars and new bike lanes.
The cameras used for vehicle detection are generally not suitable for license plate reading and red light monitoring.So they can write tix for running red lights without having to have a cop on site.![]()
There are no totally aluminum cars. The crankshaft, flywheel, cam/valvetrain, timing chain, bolts (all hardware), brake rotors, transmission gears/shafts and cv/driveshafts are steel no matter how exotic a car you buy; several hundred pounds of steel.
No cameras on the red light wire or arms only read where cars are on the road. Red light cameras are privately owned and not on state or city poles.
