M mstrlucky74 Senior Member Location NJ Feb 25, 2016 #1 Spec aside....if you had to use a 4" sq or octagon box outside wall mounted for a light,security camera etc. and it was a commercial job what type box would you install? Fs/fd, alum, pvc? Thanks
jumper Senior Member Location 3 Hr 2 Min from Winged Horses Feb 25, 2016 #2 Die cast aluminum, commonly called a bell box. https://www.hubbell-rtb.com/literature_pdf/bell weatherproof boxes covers lighting.pdf If I am running RMC, more likely FS/FD http://www.cooperindustries.com/con...dboxes/fs_fd_series_deviceboxesandcovers.html
