My question is about a Hubble LHMTS1-G-WH wall mounted sensor. I installed this unit on a 277 volt system and it is rated for that. The problem is after wiring it and properly grounding it. I found the yolk to ground to be live. I got a shock trying to mount it to the box. and it measured 277 volts to ground.
I followed up with a call to the manufacturer where I was told that this condition is normal and that the instructions clearly state not to install on a live circuit and that once mounted to the box it would no longer be a shock hazzard. I was wondering if this condition meets the rules of the NEC. thanks for any and all input
