mmontoya
- Bayonne, NJ, US
This is my first post on this site, so I apologize if I'm not posting this properly.
I’m going to try to keep this story fairly short. I’m new to fire pump installations and our office are trying to finalize a design change. This is a project that is currently in construction and the client wanted to make a change to the original design. The client wanted to add a redundant generator for the already installed on site generator. But instead of adding an actual generator, they want to add a receptacle. Everything seemed fine with this setup, but when looking at the original design, seeing what’s already installed out in the field and what the contractor/generator manufacturer are trying to do, we ran into an issue and the code doesn’t clearly state what the right approach is. The issue is when installing fire pumps you are supposed to tap ahead of everything and connect directly to the generator, but do you tap before the generator’s circuit breaker or ahead.
Also reading a few articles about fire pumps, it seems you want to keep the fire pumps running at all costs. But do you do it at the expense of destroying the generator, or do you still want to protect the generator? Any help is appreciated, thank you.
