WickidPissah617
- Massachusetts
So 250.140 allows ranges to use the neutral of a S.E. cable as a grounding means on existing [COLOR=blue !important][COLOR=blue !important]circuits[/COLOR][/COLOR] only. We've been told that if the range is relocated and you can still use the existing S.E. cable it's ok. But if you have to extend the cable to the new range location then a cable with an insulated equipment ground wire has to be installed.
What if the other end of the cable needs to be extended ? Case in point, I have a job where the existing Federal Pacific Electric (FPE) panels are being replaced. Insurance company requirement. The FPE panels are located in clothes closets. Do you think I can get the AHJ to just allow me an extension to the new panel location without replacing the entire range cable ?
