howardrichman
I'm installing a sub panel fed from a main panel that's fed from a main disconnect. When leaving the 1st distribution panel, I'm installing EMT to feed a subpanel. Do I need to install ground bushings for concentric and ground locknuts for non-concentric knockouts for all fittings and HW pipe entering a j-box or panel to secure a ground ? I could just install a ground conductor, but should not be necessary. In that case how can just a locknut/bushing alone be sufficient to carry a ground for general wiring in steel conduit between j-boxes and other terminating points?
HR...
HR...
