lielec11
- Charlotte, NC
- Electrical Engineer (PE)
I am trying to coordinate a breaker with a motor starting curve except the circuit breaker the contractor is using doesn't fall below the hot stall point on the TCC. However, this is assuming the motor is starting across the line. In reality it will be connected to a VFD.
1) Is there a way to model this?
2) If not, do I need to show the hot stall point at all when showing motor protection by a circuit breaker?
