SolarAlternativesDesign
- Soulsbyville, California, USA
I've read some suggestions that a service rated fused disconnect be used at a line side tap. One person suggested breakers. Is there a section in the code that specifies what type of OCPD and disconnect should be used? Are there operational or safety reasons for using a service rated fused disconnect instead of breakers? 2011 NEC 705.12(D) seems to be the article that addresses the connection and it doesn't specify which type.
