Double oven connection
Thank you
What always confused me is that the lockout could not be removable
It's for a Siemens panel. Would it be one of http://w3.usa.siemens.com/powerdist...ges/panelboard-accessories.aspx?ismobile=true
Thing is it says padlock device. With no pad lock it's not lockable. If you buy a pad lock where do you put it so it's not removable ?
The lockout device goes on breaker before panel cover is installed
Electrician is responsible for carrying his own padlock. It's for his own benefit , to lock the breaker off while he works on the circuit
When the breaker is in the "off" position, there is a hole to put the padlock through, to keep the breaker from being turned on until the electrician retrieves his padlock
