- New Jersey
- Journeyman Electrician (retired)
Is it acceptable to run this motor on 3Ø, 208 volts? How would you size the conductors, using the 200 volt or 208 volt column in T430.250?
200 volts is the rated voltage of a motor intended for use on 208V, just like 230V being for use on 240V, and so on....
