Weird question........ Is there anywhere in the code that states a GFCI receptacle must be placed with in X amount of feet or inches of the panel board in a residential setting? It is extremely common around my parts to see it done, until today when I didn't see one.
Follow up: I have talked to four licensed electrician that do work in our town and they all said it is required by code. I asked them to provide me the section and none of them could. Two of the four told me that that they were told to do this on all new installs while they were serving their apprenticeships. I believe they were told to do this so the other trades had a convenience receptacle to plug their tools into while the construction of the house was in process. Thoughts?
I believe that is limited to HVAC equipment.I can't site a code reference, but I was told that we put receptacles close to the panels because of a requirement for serviceable equipment to have one. If they are in an unfinished basement, they get GFCI.
Dear apprentices, your "Journeyman" should be capable of providing a code reference for anything they say is "Required" or they are JINOs :happysad:. JMO
The panel boards I am referring to are either in an unfinished basement or garage. Which need to GFCI protected but don't fall under 110.52 (A).
