RickLight
- United states of america
I need a clear code reference that portable gear being placed or moved isn't 'electrical construction' and therefore shouldn't require a permit.
Here is the story from a friend who is a stagehand. An inspector recently claimed a permit is needed to set up theatrical lighting. The job was placing a few fixtures and plugging them into the permanently installed receptacles. He probably used some extension cords.
I believe this is not construction activity in any form and no permit is needed.
In my 40 years I've never heard of such a thing. If enforced this could apply to churches using stage lighting (nearly all), bars, event centers, hotel ballrooms and maybe outdoor festivals. Do you realize how many churches and bars are in even small cities? Can you imagine inspections early Sunday morning? One could take the extreme view and say that this would prevent charging your phone at Starbucks!
- No local codes address the issue directly. It's all pretty straight NFPA70 from the state level on down.
- This is not 'temporary' it is 'portable' and the time something is in place ranges from hours to years.
- All luminaires and cords are portable equipment with NRTL listed plugs and connectors, properly powered from OCPDs.
- The only tool used is a wrench for a mounting clamp and minor luminaire adjustments.
No wires in screw terminals, bare copper is never seen unless something goes wrong. :weeping: - Theatrical dimmers and power distribution look a bit weird at first glance, but are NRTL listed and follow NEC in general and 520 specifically, of course. These are available both as permanently installed and portable versions. I'm only talking about the portable side. Large systems are typically powered using single conductors with 'cam-lok' style plugs and receptacles rated to 400A.
- Best I can find from inside the theatrical side is that only NYC requires an electrician when a Broadway show is being installed. Knowledgeable folks believe its just for the permit fees. Broadway shows are huge projects with lots of money in play. We all know NYC likes their own rules.
- Inspection is welcome any time of course. We routinely have Fire Chiefs/Marshals/Inspectors/etc on site counting crowds and such.
