wire pull
MBLES
whats the best way to pull wire up a service riser 25' on utltiy pole. what type of pulley system is a good method? is there a pipe adaptor i could use
to attach to pole while pulling from riser up the pole?
a pipe sheave, or tie rope around pole 6' above end of pipe and throw a pulley on rope
That's one way we do it, a choker around the pole with a sheave, or we feed into the top of the riser on the pole and pull out on the other end. Depends on a few variables.
