Is there a rule that commercial lighting and receptacle circuits can only be 20A?
jaylectricity
Massachusetts
licensed journeyman electrician
I'm working on the old Snap-On factory in Natick, MA and there are a bunch of NM cables feeding the lights and receptacles for the front office area.
It's a mix of threaded NM and slightly newer NM (but before yellow 12). But one cable is 14 gauge. Of course it was on a 20A breaker.
Even so, is there a rule that says you can't have a 15A receptacle or lighting circuit in a commercial environment?
infinity
New Jersey
Journeyman Electrician
In some jurisdictions, like NYC where #14 conductors are prohibited for branch circuits, you would see 20 amp circuits for everything.
GerryB
Guess I'll ask. What is threaded NM?
jaylectricity
Massachusetts
Sorry, I meant the old cloth jacket with the undersized ground. "Threaded" made sense in my head when I typed it.
Thanks iwire for the local response.
infinity
New Jersey
"Threaded" is the old type R or RW tinned copper which had fine threads around the rubber insulation.
